2651 IOS problem
Jun 8th, 2008
I have a 2651 that I tryed to upgrade the IOS by xmodem but end up deleting all configuration files, good thing is that is a lab unit.
I get the following when booting:
device does not contain a valid magic number
boot: cannot open "flash:"
boot: cannot determine first file name on device "flash:"
System Bootstrap, Version 12.2(10r)1, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 2002 by cisco Systems, Inc.
C2600 platform with 98304 Kbytes of main memory
rommon 1 >
Can someone explain step by step what files need to be loaded.
Tiago Dias
diastiago Mon, 06/09/2008 - 06:39
sirdudesly,
I am trying the setps that you mentioned, but the problem is that I am only connecting to the router by console port COM1, and the tftpd32 that I have only listen to the ethernet port, so I can not send the image file.
And by xmodem I get to many errors and the connection drops.
sugestions?
