ODBC connectivity for Third party billing software
Jun 8th, 2008
We are running UCM 6.1.2.And planning to deploy third party call billing software.
Can it possible to provide ODBC connectivity between UCM 6.1.2 and the billing software ?
Is UCM 6.1.2 supports ODBC ?
Help me out !!
Rajesh Revuru Sun, 06/08/2008 - 06:58
Hello:
With call manager 6.X, the only interface to 3rd party billing software is via ftp/sftp protocol as flat files. Cisco migrated to Informix databases with current CM, and i am not sure if they are ODBC complaint or not.
Aaron Harrison Sun, 06/08/2008 - 08:35
Whilst there probably is an ODBC interface to Informix, it's almost definately inaccessible when running on a CallManager 6.x appliance.
Any third party billing program that is compatible with CallManager 6 will support the new FTP/SFTP method, so check with your application vendor for an update.
Aaron
Please rate helpful posts...
