AS5400 and SIP/H323 Voice calls..............??????????????................
Jun 8th, 2008
Dears,
Que(1):what signal is output from AS5400.
Does it SIP or H323?
Que(2):i need to generate SIP and H323 Voice calls from AS5400 , can i do that?
if no what are your recommendations for AS5400 to be apple generate SIP and H323 Voice calls for other VoIP carriers?
Que(3): can AS5400 generate voice calls directly to other Carriers as:
AS5400 (calls SIP & H323)------to----- B carries.
any help please.
paolo bevilacqua Sun, 06/08/2008 - 06:56
  • Hall of Fame,
    Founding Member
1. Both. It is configured as "session protocol" under voip DP.
2. Yes
3. Yes
tareqrebhi Wed, 06/11/2008 - 05:35
Ok man thanks a lot.
i have this issue now:
Dear,
I tried to add new E1 to existed E1s. old E1 has slot time signalling with trunknailed called 1002, I need this New E1 without time signal mean to add to previous trunk 1002.
I added this command:
prov-add:nailedtrnk:name="1033",srcsvc="ss7p-jtc-abdali",dstsvc="naspath1-abdali",srcspan="ffff",dstspan="0",srctimeslot="33",dsttimeslot="33",spansize=31
but when I added this new E1 to old E1,old E1 can not send or receive any calls (it is down) beside that new E1 doesn't run, I tried delete it using :
prov-dlt:nailedtrnk:name="1033",srcsvc="ss7p-jtc-abdali",dstsvc="naspath1-abdali",srcspan="ffff",dstspan="0",srctimeslot="33",dsttimeslot="33",spansize=31
I added at AS5400 this commands:
controller E1 7/2
framing NO-CRC4
pri-group timeslots 1-31 nfas_d primary nfas_int 1 nfas_group 1
i delete every thing i put at PGW and AS5400.... but old E1 doesn't come up.
i need to say before adding new E1 every thing is will but after problems appeared, i have 2 E1s were running well now just one live and the other died.
i did blk and unblk at PGW but no changes at channel they still block.
i attached files for more details.
thanks for any help.
paolo bevilacqua Wed, 06/11/2008 - 05:54
  • Hall of Fame,
    Founding Member
Sorry, I can't help with SS7.
Sir,
to assist you, please send PGW configurations and your objetive: What E1s will be active in AS5400 and what are the SS7 configurations expected to work in this E1: CICs, signaling link been used.
to export PGW configuration, at the MML session, type:
prov-exp:all:dirname="20080815"
where is the name of the directory where the configurations will be saved.
this directory is created under
/opt/CiscoMGC/etc/cust_specific.
the files that interest in this case is the config.mml and the export_trunk.dat.
regards,
Daniel
tareqrebhi Sun, 06/15/2008 - 02:01
can please advise me with commands i should use to set AS5400 to originate and terminate voice calls in both SIP and H323?
islam.irshaid Tue, 06/17/2008 - 04:25
dears
can you please help if i can use MGCP with AS5400XM or not ???
