IBM Blade Switch unable to PING Mangnt VLAN 1 interface
Jun 8th, 2008
I've spent a tough weekend trying to get an IBM blade switch working with a Catalyst Express 500G
(no console port on these - dodgy GUI too, avoid if possible)
The Virtual servers are all on the same subnet.
I've trunked the blade ports anyhow but everything is in VLAN 1.
The Blade Switch links to the Express 500G which then connects to the user LAN using a Netgear unmanaged (no trunking capability either)
The Express 500G automatically decides it wants to trunk if it's told it is connected to another switch which is awkward.
I'd really apprecaite someone taking a look at this config and guess why I can not PING or telnet to the VLAN 1 IP address?
Best Regards Tony
PS I thought this was going to be a nice easy weekend.....not
vtp domain *****
vtp mode transparent
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
vlan 2
interface Port-channel6
switchport mode trunk
interface GigabitEthernet0/1
description blade1
switchport trunk allowed vlan 1-1005
spanning-tree bpdufilter enable
interface GigabitEthernet0/2
description blade2
interface GigabitEthernet0/3
description blade3
interface GigabitEthernet0/4
description blade4
etc
interface GigabitEthernet0/14
description blade14
interface GigabitEthernet0/15
description mgmt1
switchport nonegotiate
spanning-tree cost 100
interface GigabitEthernet0/16
description mgmt2
interface GigabitEthernet0/17
description Link to Cat500 Preston_Sw3
channel-group 6 mode active
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface Vlan1
ip address 192.168.0.22 255.255.255.0
no ip route-cache
management
ip default-gateway 192.168.0.1
ip http server
snmp-server community public RO
snmp-server community private RW
line con 0
line vty 0 4
login local
line vty 5 15
login local
end
BladeSw1#sh vlan
VLAN Name Status Ports
1 default active Gi0/4, Gi0/5, Gi0/6, Gi0/7
Gi0/8, Gi0/9, Gi0/10, Gi0/11
Gi0/12, Gi0/13, Gi0/14, Gi0/16
Gi0/19, Gi0/20
2 VLAN0002 active
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
Overall Rating: 4 (1 ratings)
glen.grant Sun, 06/08/2008 - 17:50
  • Purple, 4500 points or more
Where is the actual bladeserver management module plugged in ? The cisco switches do not ping out thru the switch connections to the network they actually ping back out thru the bladeserver management module. Normal traffic flows out the switch links but management of the cisco blade switches actually flows out thru the bladeserver server MM so I would check to see where that is plugged in .
tholmes@cistek-... Mon, 06/09/2008 - 02:37
Hi Glen,
That sounds like the cause of the problem, as yet I'm not sure where the MM is connected but I'm sure that'll be the reason.
Do you think the config is ok?
This is a relocation job and the blade switch was set up with trunking to the blade servers even though the new location and all the servers are on the same nsubnet.
As the Netgear LAN doesn't support VLAN trunking there was no point in making the Server and Management VLANs different subnets.
Many thanks for your help
Regards Tony
