kamarul83 Mon, 06/09/2008 - 17:56
First of all, thanks for your reply.
After I configured the AP1240, the software status still disabled and the hardware still down.
FYI, I have two of AP1240 and one 1300 Series Outdoor. For the AP1240, i configured as WGB and 1300 as Access Point.
Before this, all device working properly until last month. The AP1240 doesnt work but the 1300 Outdoor still working properly.
Did you have any idea what happen to my AP1240?
kamarul83 Mon, 06/09/2008 - 22:23
kamarul83 Tue, 06/10/2008 - 00:39
Below is the configuration that i copy for config.txt
version 12.3
no service pad
service password-encryption
hostname ap
enable secret 5 $1$Gl9g$EL6iBO/Yfu.fskfJiY1rI.
ip subnet-zero
ip domain name m
no aaa new-model
dot11 ssid Myport
authentication open
power inline negotiation prestandard source
crypto pki trustpoint TP-self-signed-1842759256
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1842759256
revocation-check none
rsakeypair TP-self-signed-1842759256
crypto ca certificate chain TP-self-signed-1842759256
certificate self-signed 01 nvram:IOS-Self-Sig#3601.cer
username Cisco password 7 032752180500
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid Myport
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role workgroup-bridge
infrastructure-client
bridge-group 1
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface BVI1
ip address 192.168.1.134 255.255.255.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
line con 0
line vty 0 4
login local
end
kamarul83 Tue, 06/10/2008 - 01:11
I'm sorry. I'm not really understand. Could you please explain it to me?
kamarul83 Tue, 06/10/2008 - 01:15
I'm sorry. What do you mean Interface dot11radio0 no shut?
kamarul83 Tue, 06/10/2008 - 01:30
I've already select enable for the radio but the radio still =disable/down.
Below is the config;-
version 12.3
no service pad
hostname ap
ip subnet-zero
ip domain name m
no aaa new-model
dot11 ssid Myport
authentication open
bridge irb
no ip address
no ip route-cache
ssid Myport
bridge-group 1
no ip address
no ip route-cache
shutdown
station-role root
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface BVI1
no ip route-cache
ip http server
control-plane
bridge 1 route ip
line con 0
line vty 0 4
login local
end
kamarul83 Tue, 06/10/2008 - 01:41
version 12.3
no service pad
hostname ap
enable secret xxx
ip subnet-zero
ip domain name m
no aaa new-model
dot11 ssid client
authentication open
username Cisco password xxx
bridge irb
no ip address
no ip route-cache
ssid client
bridge-group 1
no ip address
no ip route-cache
shutdown
station-role root
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface BVI1
no ip route-cache
ip http server
control-plane
bridge 1 route ip
line con 0
line vty 0 4
login local
end
kamarul83 Tue, 06/10/2008 - 02:01
oh. i'm sorry. i thought you want me to change the SSID. Do you mean the Client Authentication Setting?
kamarul83 Tue, 06/10/2008 - 02:14
FYI, for the primary AP (1300 series outdoor)still on the site.
below is current 1240AP:-
version 12.3
no service pad
hostname ap
enable secret xxx.
ip subnet-zero
ip domain name m
no aaa new-model
dot11 ssid client
authentication open
bridge irb
no ip address
no ip route-cache
ssid client
bridge-group 1
no ip address
no ip route-cache
shutdown
station-role root
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface BVI1
no ip route-cache
ip http server
control-plane
bridge 1 route ip
line con 0
line vty 0 4
login local
end
OK - so I have been in my lab and found the following that would create the same situation that you are seeing:-
1) The radio interface on the root AP is down - then the workgroup ap radio interface would not come up.
2)The radio interface on the root AP as an ssid - then the workgroup ap radio interface has a different ssid in the radio interface, then it would not come up.
3) The radio interface on the root AP has encryption enabled - then the workgroup ap radio without the same encryption on the interface would not come up.
4) The radio interface on the root AP has encryption enabled, with a pre-shared key - then the workgroup ap radio with the same encryption but no pre-shared key on the interface would not come up.
5) The workgoup bridge AP is not close enough to the current root AP.
The above is all I could test in my lunch hour.
HTH.
kamarul83 Wed, 06/11/2008 - 01:16
Thanks.
I will let you know if i have a AP1300 Series configuration.
Also keep you update if there have a improvement of AP1240.
tonyspcrepairs Sat, 06/14/2008 - 12:59
andrew I wanted to say thanks for posting this link. I've been wrestling for hours with my AP1242AG access point and could not get it to work as a bridge but the link you gave cleared it all up.
Cheers, Tony
