moving network objects CISCO PIX V7
yann.boulet
I have 3 networks with objects groups on an dedicated interface, i want to move those objects on three interfaces directly connected, what is the best way to keep nat, acl and objects.
Do i need to remove all ? and recreate ?
Thank you
Farrukh Haroon
I don't undertand your question exactly. But you could just add the three new networks to the object-group and THEN delete the old. This was the ACLs etc. should update automatically. Or is it that you want to break ONE existing object-group into three?
Farrukh
thank you for your reply
network are the same and objects also, i just want to move the configuration from an interface with the three networks on 3 virtual interface with those networks directly connected.
