some trouble with webvpn
Jun 8th, 2008
Hello - when i confogure my asa 5520 with software 8.0(3) I have next problem:
When i enter to secure desktop and print my login and passwd i see "incorrect login"
on asa i see this:
INFO: debug webvpn enabled at level 200.
HMCIS-Firewall# webvpn_auth.c:webvpn_auth[476]
WebVPN: no cookie present!!
webvpn_portal.c:ewaFormSubmit_webvpn_login[1826]
ewaFormSubmit_webvpn_login: tgCookie = 0
ewaFormSubmit_webvpn_login: cookie = c9938928
ewaFormSubmit_webvpn_login: tgCookieSet = 0
ewaFormSubmit_webvpn_login: tgroup = NULL
webvpn_portal.c:http_webvpn_kill_cookie[632]
webvpn_auth.c:http_webvpn_pre_authentication[2009]
WebVPN: calling AAA with ewsContext (-932106496) and nh (-932109336)!
WebVPN: started user authentication...
webvpn_auth.c:webvpn_aaa_callback[4537]
WebVPN: AAA status = (REJECT)
webvpn_auth.c:http_webvpn_post_authentication[1233]
WebVPN: user: (evkuzin) rejected.
http_remove_auth_handle(): handle 76 not found!
But radius logs a clean!!!
what wrong?
Overall Rating: 4 (1 ratings)
Farrukh Haroon Mon, 06/09/2008 - 02:22
  • Red, 2250 points or more
Did you check the Radius connectivity with the AAA server using the 'test' command on the ASA?
Farrukh
vadim.kharchenko Mon, 06/09/2008 - 03:14
Yes - i'm sure that the connection to radius work propertly because beside webvpn i configure remote ipsec vpn with authentification on this radius and it's work.
Farrukh Haroon Mon, 06/09/2008 - 23:36
Were you able to get this working?
Farrukh
vadim.kharchenko Tue, 06/10/2008 - 01:26
It's not work :(
But i noticed the following issue:
If i write login & pass any users from AD, then i see "incorrect login" and in debug webvpn "AAA status = (REJECT)"
If i write login & pass my admin user with priv 15 - i see on debug webvpn "AAA status = (ACCEPT) and on login page "Login denied, unauthorized connection mechanism, contact your administrator."
I don't know why... (((
vadim.kharchenko Tue, 06/10/2008 - 03:12
I think that in the settings webvpn I should enter tunnel-group test. But where... :)
Farrukh Haroon Tue, 06/10/2008 - 05:12
I think your current WebVPN is landing on the DefaultRAGroup (the configuration of which is missing from the text file you attached in your first post), use this link to configure your ASA such that you can 'select' the tunnel-group at logon time:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00808bd83d.shtml
This way, at least you know no which tunnel-group you are landing.
Farrukh
vadim.kharchenko Tue, 06/10/2008 - 09:16
Yes - thank you. Now it's working. But in cfg i don't see DefaultRAGroup...
Farrukh Haroon Tue, 06/10/2008 - 23:32
Did you try
"show run all tunnel-group"
It should be there
Farrukh
