About Routeplan
Jun 8th, 2008
Hi all
We have 3 PSTN trunk ie 2 digital(E 1) and 1 analog(FXO). According to my routeplan first priority is for E1(primary),E1(secondary) and Analog FXO. I attached my Gateway configuration.
My internal numbering plan is 7xxx and my DID Range is 7000-7999. We have 10 lines for emergeny ie analog fxo. its numbers are 4926620-29. when i trying to call outside number somtime it takes analog trunk and some times it takes digital. Now i am confused about my configuartion. Any one can explain it will be appreciate...
Nahas
Aaron Dhiman Mon, 06/09/2008 - 12:17
The decision for which gateway your UCM routes calls to will depend on the Route Group/Route List configuration in the UCM. Do you have all of the gateways in a single Route Group currently, or in different Route Groups?
Nahassamad_2 Mon, 06/09/2008 - 19:41
Thanks for your reply...
Yes. we have only one route group. The three gateways are in same route group.
Nahas
Aaron Dhiman Thu, 06/12/2008 - 07:07
You then need to ensure that you set the Distribution Algorithm on the Route Group config page to "Top Down" from "Circular".
