Upgrade problem
Jun 8th, 2008
I have a question about cisco asa upgrade.
I try to upgrade version 8.0.2 to 8.0.3 via rommon. The upgrade have success. When i reload the cisco asa i see the version 8.0.3 but into the flash i don't see the file. Could you help me?
husycisco Mon, 06/09/2008 - 01:27
  • Gold, 750 points or more
Hi alessandro,
Image installation or upgrade in rommon mode extracts the image to RAM and starts your startup config with the image for you to see if there are any inconsistencies. You should manually copy the new image to flash either in rommon or in priv mode after the extraction...
copy tftp://tftpserverip/8.0.3image.bin flash:image
taungpawtar75 Fri, 06/13/2008 - 09:56
Hi Sir
I have a question related to IOS for ASA. I have two IOS ver on ASA 7.2 and 8.03. Currently it use 7.2. If I tell ASA to use 8.03 which already in ASA, will it ask to reload ASA?
Noom
Farrukh Haroon Fri, 06/13/2008 - 11:51
  • Red, 2250 points or more
Yes it will have to reload.
Farrukh
