06-09-2008 01:34 AM - edited 03-05-2019 11:30 PM
This switch is using the CATOS for layer 2 and IOS for Layer 3, So currently the CATOS is running well but the Layer 3 in the ROMMON, pls refer to below:
rommon 1 > boot sup-slot0:c6msfc-dsv-mz.121-27b.E1.bin
an alternate boot helper program is not specified
(monitor variable "BOOTLDR" is not set)
and unable to determine first file in bootflash
loadprog: error - on file open
boot: cannot load "sup-slot0:c6msfc-dsv-mz.121-27b.E1.bin"
Is it Have any idea to boot it up.
-Gilbert
06-09-2008 02:15 AM
Try the "boot slot0:c6msfc-dsv-mz.121-27b.E1.bin" command.
(dont use sup-slot0:, just slot0:)
Also, when you get the MSFC running, goto global config mode and enter the "boot system flash slot0:c6msfc-dsv-mz.121-27b.E1.bin" command to set the boot file to load automatically.
06-09-2008 03:34 AM
I believe the old Supervisor 1's need to have a bootloader image loaded into msfc bootflash with the corresponding boot statement to boot up correctly . Go out and get the bootloader image that goes with this version and load it into "MSFC" bootflash and set your boot statement to reflect this , "boot bootldr bootflash:
06-09-2008 05:54 PM
I had tried the command which suggested but it come out the message as below:
rommon 2 > boot slot0:c6msfc-dsv-mz.121-27b.E1.bin
boot: cannot load "slot0:c6msfc-dsv-mz.121-27b.E1.bin"
rommon 3 >
pls advise
-Gilbert
06-09-2008 10:04 PM
Is it any 1 can help on this issue.
Much Appreciate for the help.
-Gilbert
06-10-2008 08:08 AM
Anybody help on this issue.
Thanks a lot
-Gilbert
