WAN (MPLS) query
Jun 9th, 2008
Hi All,
I have cisco 2821 connected with an MPLS link which supports two networks (Network A (Data), Network B (Data & Voice))
We a new MPLS link willing to terminate on the same router 2821 which will support Network B (Data & Voice)
Condition: Network A (Data) and Network B (Data & Voice) should not communicate.
Note: EIGRP is running at the backend of the MPLS Network
Which are the new things to be implemented?
Kindly suggest whether this works/will there is be any bandwidth choke?... Any suggestions would be highly appreciated.
Thanks in advance...
paolo bevilacqua Mon, 06/09/2008 - 03:44
  • Hall of Fame,
    Founding Member
Hi, you can do that by either policy routing, or VFR lite. Suggest you search on the subject and choose the technique that you like better.
For bandwidth considerations you should mention you circuit speeds and the intended usage for data/voice etc.
networkeng007 Thu, 06/12/2008 - 10:15
Alright, Thanks buddy!! will check abt the bandwidth considerations...
