ASSERTION FAILED: in AS 5300
Jun 9th, 2008
i am getting the following error in my AS5300 access server
ASSERTION FAILED: file "../as/if_as_pm7366.c", line 129
6
ASSERTION FAILED: file "../as/if_as_pm7366.c", line 149
running ver is c5300-i-mz.123-26.bin
Richard Burts Mon, 06/09/2008 - 02:58
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
ARVINDER
ASSERTION FAILED is a symptom of a software problem. As a short term action I wonder if a reload of the AS5300 would stop the error messages. Probably a longer term action would be to upgrade to a newer version of code.
If the router is under a maintenance contract it would be appropriate to open a case with Cisco TAC about this.
Rick
Sushil Kumar Katre Mon, 06/09/2008 - 04:27
  • Gold, 750 points or more
Hi ARVINDER,
I have no idea about this error. But while going through few documents I stepped on to this bug -
CSCdm55659
The CT1 PRI on the double-density version of a Cisco AS5300 series access server might not operate properly when it is configured with a channel group and Frame Relay encapsulation on the serial port. The following error message might result when you configure the channel group:
23:31:18: ASSERTION FAILED: file "../as/if_as_pm7366.c", line 1291 23:31:18: ASSERTION FAILED: file "../as/if_as_pm7366.c", line 1491
There is no workaround.
http://www.cisco.com/en/US/docs/ios/12_0/release/notes/120tcavs.html - Resolved Caveats-Cisco IOS Release 12.0(7)T
I know you are running 12.3 IOS release. But though this might give you some clue.
-> Sushil
