2960 Port Security
Jun 9th, 2008
Hi All
I'm having a bit of a dilema configuring some 2960 switch ports for port security.
Each Port must only see one legal device connected to it and shutdown should someone connect an illegal device.
I have configured the port accordingly. But if I have the switchport port-security max set to 1, nothing works and if I set it to, 2 everything works including illegal devices ..
I cannot see for the life of me whatI am doing wrong .. can any one advise ?
interface FastEthernet0/14
switchport access vlan 2
switchport mode access
switchport port-security max 2
switchport port-security mac-address xxxx.xxxx.xxxx
speed 10
duplex full
spanning-tree portfast
spanning-tree bpduguard enable
Collin Clark Mon, 06/09/2008 - 05:52
  • Purple, 4500 points or more
The default is 1 address, so I don't think you need the statement. Here's an example of ours.
switchport port-security violation restrict
switchport port-security mac-address 0000.2222.4444
Hope that helps
thestagman Mon, 06/09/2008 - 06:17
Hello Collin
Thats worked a treat, I just removed the max setting and it all worked. Why I didn't think of that I just don't know ..
Thanks for your time
Mike
