WAAS Veritas NetBackup
Jun 9th, 2008
Has anyone had any experience or good results with optimizing NetBackup traffic with WAAS? The NetBackup traffic is getting classified by the WAE's in my environment, but I am seeing little if any optimization for this type of application traffic.
dstolt Tue, 06/10/2008 - 09:25
  • Cisco Employee,
Michael,
The default policies for Netbackup is the following:
Veritas-NetBackup
Optimization: TFO
Ports: 13720, 13721, 13782, 13785
This is "TFO only" which won't give you any compression, only the ability to "fill the pipe". Is your Netbackup traffic already compressed and/or encrypted over the wire? If you turn those features off, chances are you could see really good compression after turning on Full optimization for the Veritas Netbackup application profile.
Just something to try...but I wouldn't recommend turning on DRE/LZ if the app is already doing the compression or encryption.
Dan
