Max. no of Suported IP phone
Jun 9th, 2008
Dear all,
I have Cisco 2811 with CME 12.T version, the present setup have max. no of IP Phone support is 48, If i want to add more phone what additional license/card or module i need to purchase?
This Box will support more phones or not, i want to know.
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Mon, 06/09/2008 - 05:15
Actually a 2811 should support only 36 phones, and will not support more than that (actually a bit more, type ? after max-ephones).
There are no licenses that you can buy to increase that number.
As a workaround you can configure additional phones in SIP, but I would NOT recommend that and you should buy a bigger router instead.
amanyelukar Tue, 06/10/2008 - 21:14
Wat about Cisco 2821 (revision 53.51) with 249856K/12288K bytes of memory.
Is it restricted to 48 IP phones ?
