Modify idle timeout value for LAN to LAN IPSEC Tunnel
Jun 9th, 2008
Hi Folks,
I have an ASA with several LAN to LAN IPSEC tunnels configured and having VPN drop outs if we leave our session idle for sometimes as little as 5 minutes.
Can this be increased to something more realistic, say 60 minutes +?
Chandru
Farrukh Haroon Mon, 06/09/2008 - 12:46
  • Red, 2250 points or more
Do you have crypto isakmp keepalives configured?
Also what is the idle time currently configured for phase 1 and phase 2?
Farrukh
ckuriyar74 Mon, 06/09/2008 - 22:47
Yes, I have configured crypto isakmp keepalives.
crypto isakmp policy 30
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
Chandru
Farrukh Haroon Mon, 06/09/2008 - 23:04
Can you please post the output of the following:
show run crypto
show crypto protocol statistics ipsec
show crypto map detail
Also what values have you used in the crypto isakmp keepalive command?
Is there any firewall in the transit path?
Farrukh
Farrukh Haroon Mon, 06/09/2008 - 23:21
Also I forgot the most important command
show run all group-policy
I'm just looking for the
vpn-idle-timeout and vpn-session-timeout commands in there. They are used to set the idle/absole timeouts for VPN connections. You can increase them and check.
Farrukh
Farrukh Haroon Tue, 06/10/2008 - 00:28
Please configure the following and test:
group-policy DfltGrpPolicy attributes
vpn-idle-timeout none
Or set it to something higher? Default is 30 minutes of idle time.
Farrukh
