UCC Reason Codes
Jun 9th, 2008
Does anyone know where i can find agent reason code definitions for UCC 5.0? We don't have any custom codes set up but our agent reports are getting a 32755 code and i can't find out what the code actually means.
Steve Luciano
rbua Mon, 06/09/2008 - 05:32
Hi Steve,
hope this helps:
Reason Code: 32755
State: Not Ready
The system issues this reason code when an agent is moved to the Not Ready
state after
handling a Unified CCX call. This situation occurs in one of two cases:
. If an agent (Agent 1) was in the Not Ready state and gets a consult
Unified CCX call
from another agent (Agent 2). In this case, after handling the call,Agent 1
moves back to
the Not Ready state.
. If an agent's Automatic Available option is disabled and this agent gets a
Unified CCX
call, then this agent goes to the Not Ready state after handling the call.
You will get the above reason code for one of the two states
sluciano Mon, 06/09/2008 - 05:36
OK...since we don't use Automatic Enable could an agent that was on Not Ready receive a call from anyone other than the unified CCX and get that code?
thanks for the help....
rbua Mon, 06/09/2008 - 05:39
Hi Steve,
it might if they got it on their CC line and not their private one. Lines are still monitored, call should have been manually routed by another agent.
rbua Mon, 06/09/2008 - 05:40
Just for the sake of it, here is the complete list:
32755 Call ended
32756 Device in service
32757 CallManager failover
32758 Work timer expired
32759 Device out of service
32760 Logon
32761 Non-ACD call
32762 Off hook
32763 Ring no answer
32764 CRS failover
32765 Connection down
32766 Forced logout
32767 Forced login
