Standard ACL question/problem
Answered Question
Jun 9th, 2008
Hi!
I'm having problem with an ACL that I think should work.
Got two 1721 connected with serial interfaces with each other.
Each 1721 has a loopback interface (for ping purpose/simulate PC on each side)
the mission is to block traffic each routers lan (loopback interfaces)
Router1:
Loopback0 192.168.101.1
Serial0
192.168.1.1
Router2
192.168.100.1
Serial0
192.168.1.2
This is the ACL on router1:
Standard IP access list 3
10 deny 192.168.101.1
20 permit any
That ACL is bound on my serial0
interface Serial0
ip access-group 3 out
im doing a source ping from my router1 loopback0 towards the router2 loopback0 This works... but my ACL should prevent all traffic
What am i doing wrong?
If i use the same ACL on router2's S0 then it works.. but router1 s0 ACL out command should prevent it anyhow?
router1#ping
Protocol [ip]:
Target IP address: 192.168.101.1
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 192.168.100.1
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 192.168.101.1, timeout is 2 seconds:
Packet sent with a source address of 192.168.100.1
Correct Answer by svermill about 8 years 8 months ago
You're not doing anything wrong. It's just that locally-generated traffic from a router is not evaluated by any ACLs on the same; only transit traffic is evaluated. There are tricks you can play with setting a policy up to bounce locally-generated traffic against a loopback interface, but that's Stupid Router Trick stuff...
http://blog.internetworkexpert.com/2008/02/13/tricks-with-local-policy-routing/
Overall Rating: 5 (1 ratings)
Correct Answer
svermill Mon, 06/09/2008 - 06:22
