CCM 6.1 and Ring Down Lines
Answered Question
Jun 9th, 2008
Have a trading desk where user have ring down line being delivered to FXO. The ring down lines will recive and make call (when the FXO goes off hook the system rings out). I need to have a button that can recive calls and when press will bring the FXO off hook on the same button. Has anyone done this before.
Correct Answer by Tim Smith about 8 years 7 months ago
The PLAR out is no problem..
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080232b9f.shtml
The only thing is.. each FXO have to be configured in its own route group and route list..
So the CSS of the line will have to be unique for each phone so it can point to a specific FXO.
For inbound - if you use MGCP.. configure an Attendant DN on each FXO port.. configure it to the "hotline button" dn on each phone.
Cheers,
Tim
Overall Rating: 5 (4 ratings)
e.huntley Mon, 06/09/2008 - 07:08
Yes, you will want to configure PLAR.
The best way is configure your gateway as H323. You will do a PLAR in the CCM that goes outbound on that button over the specified FXO port. Then you will configure that FXO port with a connection-plar xxxx to the DN you add to that button on the phone for inbound.
blackmichael Mon, 06/09/2008 - 07:12
The issue with doing it like that is the phone is going to be registerd to a CM (not cme). How can i configure the line to PLAR from the CCM to take the FXO off hook as soon as the line pressed on the phone. I still also need to recive calls on same button.
Tim Smith Mon, 06/09/2008 - 07:09
Is it CallManager you are using?
Are you using MGCP or H323 for the gateway with the FXO's on them?
When the user presses the button and goes off hook.. are they dialling extra digits? or do you want it to be a PLAR or hotline?
Cheers,
Tim
blackmichael Mon, 06/09/2008 - 07:13
Yes its CallManager
The gateway can use either MGCP or H323 which ever is needed. When they go off hook they are not dialing i want it to be a PLAR/Hotline.
Mike
Correct Answer
Tim Smith Mon, 06/09/2008 - 07:30
Cheers,
Tim
Tim Smith Mon, 06/09/2008 - 10:28
Yep should do it... you will have to configure the button as a DN / line. So just associate the hotline CSS to this line. Put your normal CSS on the phone itself.
Cheers,
Tim.
