Could not PING servers on the LAN form a VPN Client
Answered Question
Jun 9th, 2008
Hi All,
Users are not able to ping servers on the LAN when connected via VPN to ASA5510 configured are Active/Standby failover pair. They could connect via VPN but couldn't PING or launch Microsoft Outlook. I included the command "crypto isakmp nat-traversal 20" but users still could PING. I increased the value to 360. Still no luck.
Also, four out of the six L2L tunnels came up and I could pass traffic over them. But two came up and goes down in less than half a second. For the remaining two, I got the following errors in the ASA log:
4|Jun 07 2008|15:58:44|113019|||||Group = 220.x.x.194, Username = 220.x.x.194, IP = SHANGHAI-PIX, Session disconnected. Session Type: IKE, Duration: 0h:00m:32s, Bytes xmt: 0, Bytes rcv: 0, Reason: Phase 2 Error
3|Jun 07 2008|15:58:44|713902|||||Group = 220.x.x.194, IP = 220.x.x.194, Removing peer from correlator table failed, no match!
1|Jun 07 2008|15:58:44|713900|||||Group = 220.x.x.194, IP = 220.x.x.194, construct_ipsec_delete(): No SPI to identify Phase 2 SA!
3|Jun 07 2008|15:58:44|713902|||||Group = 220.x.x.194, IP = 220.x.x.194, QM FSM error (P2 struct &0xd5830b58, mess id 0x8508c326)!
From the log in the ASDM, I was asked to contact the Cisco TAC if the problem persists.
Any ideas on what I might be doing wrong would be much appreciated.
Find attached my config as well.
Best regards.
Correct Answer by Farrukh Haroon about 9 years 2 weeks ago
WoW! pretty long config there :).
Try to check your split tunnel ACLs, also what is the point of split tunneling (specified) if your ACL = any? Why not leave out the split tunneling altogether?
Also for the Site to Site VPNs, why do you have two crypto maps for each site? 3DES/DES?
Seems to be a Phase 2 mismatch. Also make sure PFS is enabled on both sides and using the same DH group (phase 2 DH group).
Farrukh
Overall Rating: 5 (1 ratings)
Correct Answer
Farrukh Haroon Mon, 06/09/2008 - 12:45
  • Red, 2250 points or more
Farrukh
a.ajiboye Thu, 06/12/2008 - 23:48
Thanks for your response Farrukh. I have modified the crypto maps.
I want split tunneling for the VPN clients. How do I tidy up my config in order to allow split tunneling?
Best regards.
nomair_83 Sun, 06/15/2008 - 04:54
  • Bronze, 100 points or more
I have a doubt on your ST acl's...
That's y u r facing QM FSM errors.
do mention your networks in ST Acls ( without use any)
a.ajiboye Fri, 07/11/2008 - 01:11
Thanks everyone for your help.
I removed the "any" and specified the networks I want VPN users to access behind the ASA, disabled PFS for the site-to-site VPN and removed duplicated crypto maps and a few more tweaking and that fixed the problem.
Regards.
liaqath2k7 Mon, 06/16/2008 - 01:52
after connecting the through the vpn clinet just check the statistics of the vpn client that whether you are getting the required routes in that.
