Broadcast Domain Design
Jun 9th, 2008
  • Bronze, 100 points or more
Anyone know the recommended size (number of hosts) or limit for a broadcast domain?
Documentation much preferred.
Thanks in advance,
Craig
Overall Rating: 3 (2 ratings)
Collin Clark Mon, 06/09/2008 - 07:03
  • Purple, 4500 points or more
I don't know of any official documentation, but typically 250 hosts is the maximum for Windows ( you can go higher with Linux). This is also keeps subnetting at a minimum and helps in overall IP design as well.
Hope that helps.
cowetacoit Mon, 06/09/2008 - 07:04
The smaller the better! /24 is probably the maximum number of IP's you would want on a given subnet.
massimiliano.se... Tue, 06/10/2008 - 05:55
  • Silver, 250 points or more
This is a very good question.
The number of hosts in a subnet depends on many considerations you have to do in planning and designing a network.
Among these considerations there is a security issue: if you want, for example, segment hosts in VLAN and then create different broadcast domains. But the main consideration is:" What applications and operation systems you have?". If you have the possibility, use a network analyzer in order to determine the broadcast traffic. If this is high possibly reduce the subnet hosts.
I hope this helps.
Best regards.
Massimiliano.
