Vlan ID Translation - Vlan Mapping
Jun 9th, 2008
Hi all,
I'm having issue in configuring Vlan-to-Vlan mapping.
I'd like to "masking" a Vlan ID "X" in Vlan "Y" for transporting it, using a Layer 2 Trunk starting from a 6500 IOS Switch, to another switch (6500 CatOS)
I used command found on Cisco docs and put them only to the first switch (6500 IOS).
Does anybody know if I must put other IOS command to the second one?
In attachment my switches configuration.
Thanx in adv 4 any help.
hadbou Fri, 06/13/2008 - 06:00
  • Bronze, 100 points or more
This example shows how to map another VLAN to an existing VLAN group name:
Console> (enable) set dot1x vlan-group engg-dept 4
Vlan 4 is successfully mapped to vlan group engg-group.
I think that the command should be given on the second awitch also with the vlan id of the first switch.
for more information about this command refer:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/8.x/command/reference/set_f_l.html#wp1070704
