SCP the ASA running-config to remote server
Jun 9th, 2008
cisco24x7 Mon, 06/09/2008 - 09:01
Use RANCID for backing your configuration.
RANCID can use ssh so it is very secure.
khinze Mon, 06/09/2008 - 09:26
Thank you for your reply.
I have looked at RANCID but haven't gotten buy off yet to install/use it.
I was hoping to find an easy solution in the interim.
Farrukh Haroon Mon, 06/09/2008 - 18:16
The ASA has built-in commands to do this, but still uses TFTP. Maybe you can encrypt the TFTP traffic generated on the box (Just an idea, never tried it).
Also there is a better formatted script here:
