Troubleshooting intermittent network outages on a Catalyst 3548XL.
Jun 9th, 2008
I have a client with four Catalyst 3548XL switches (containing 4 VLANS) that are experiencing sporadic network outages. During the failure, users lose connection to the network drives on the servers, printing fails, and the internet cannot be accessed. The failures affect all vlans, and the network seems to restore itself after 10-15 minutes.
The failures could potentially be isolated to the switch containing the servers, as printing, drive shares, and DNS requests all go through that switch... however, I am not seeing anything in the event logs of the servers to indicate a problem here.
The switches are all running IOS 12.0(5)XU. The show diagnosticlog shows me that many (not all) of the ports are changing states from up to down and back again. The show diag link-flap shows me that some ports are experiencing a large amount of link-flap errors (relative to other ports, but i don't know if 497 is an excessive number), but again, I can't isolate to a root cause from here.
Can anyone give me some troubleshooting tips here? As you can probably tell, I am a cisco newbie. Are there othere diagnostic logs available to me on the switches that I am unaware of? I will attach one of the configs.
thanks,
scott
cowetacoit Mon, 06/09/2008 - 10:26
Can you post a show span? I would turn off spanning-tree portfast default. Sounds like a spanning tree convergence problem or loop.
cowetacoit Mon, 06/09/2008 - 10:28
Why do you have this port configured for access and trunk?
interface FastEthernet0/2
duplex full
speed 100
switchport access vlan 999
switchport trunk pruning vlan 3-1001
switchport mode trunk
I would change to
duplex full
speed 100
switchport mode access
no switchport trunk pruning vlan 3-1001
no switchport mode trunk
no spanning-tree portfast
scottmilner Mon, 06/09/2008 - 10:35
Jun 9, 2008, 11:28am PST
duplex full
speed 100
I didn't build the account... I was handed it a few months ago, and am still getting a feel for how things are laid out. This is a recent problem, so until this time, the switch configs hadn't been looked at. I will do some reading, but can you tell me why you would make the change?
scottmilner Mon, 06/09/2008 - 10:32
sure. as I look, it looks like spanning-tree portfast is enabled on each port.
Can you help me out a bit? What is spanning-tree portfast? I read a bit on it from the Cisco website, and without understanding everything fully, it sounded like it is recommended by cisco as a security measure.
cowetacoit Mon, 06/09/2008 - 10:36
portfast should only be used on edge ports, connecting to devices where a network loop is impossible. So a printer or phone would be ok. I don't trust some people so i leave it off. Basically it will "trust" that port not to ever have a network loop. So if someone plugged a patch cable in to the switch and then back into the switch STP would never know to shut one of the ports down. "no spanning-tree portfast default". This may not be the problem but it's a start.
post a SHOW LOG too.
dominic.caron Mon, 06/09/2008 - 10:53
  • Silver, 250 points or more
STP will block the port even with portfast enable. Problem is traffic will have time to pass before the firtbpdu. I would still recommand bpduguard when using portfast to help preserve the topology.
dominic.caron Mon, 06/09/2008 - 10:37
The link flap output is the number of up-down event since the last reboot of the switch. Is it excessive...depends on your users and uptime.
The first bad thing here is your version. It's a limited deployment train full of bug. You need to use 12.0(5)WC.
For you issue, is it a inter-vlan issue or is it also intra-vlan. If its intra-vlan, could be a spanning tree issue.
Can you do a "sh spanning-tree vlan" for all you vlan and check the number of changes(line 6 or 7 of the output)
cowetacoit Mon, 06/09/2008 - 10:57
Please run....
show logging
and
show spanning-tree vlan
you did spanning-tree vlan 1. Do you have more than one vlan? What are you using for inter vlan routing?
scottmilner Mon, 06/09/2008 - 11:13
Sorry... here are the spanning-tree printouts for the other two vlans.
There is a Cisco 2621 which is the primary router for the school, which I think is also handling the inter vlan routing. I have attached its config also.
scottmilner Mon, 06/09/2008 - 11:25
cowetacoit
Jun 9, 2008, 11:57am PST
Please run....
show logging
and
sorry... thread got confusing. show logging is above and show spanning-tree for the other vlans are below.
dominic.caron Mon, 06/09/2008 - 11:00
What about the other vlan?
What's the uptime?
Find your root STP switch and change the priority to 100. Never leave it at the default value.
spanning-tree vlan 1 priority 100
spanning-tree vlan 2 priority 100
etc.
This will cause a topology change. 45 seconds downtime.
scottmilner Mon, 06/09/2008 - 11:22
I posted the other two show spanning-tree vlan configs above.
I know, I am emphasizing my ignorance here, but I would assume that I would want (or hope) that my root STP switch contains the DC's and fileservers for my network... is that a true statement? What exactly will setting its priority to 100 do? Do I just need to be sure its priority is higher than the other three switches?
And I can't thank you enough for the help you and cowetacoit have been giving... Thanks!
cowetacoit Mon, 06/09/2008 - 11:27
The root bridge just controls the STP on your network. Did you disable portfast default?
scottmilner Mon, 06/09/2008 - 11:30
I haven't made any changes yet...I think portfast is still enabled on all active ports. I am taking notes on everything you and dominic are suggesting.
School is still in session, so I will need to implement changes after hours. We have had enough issues in the last couple of weeks that even a minor outage will ruffle a lot of feathers.
