06-09-2008 10:35 AM - edited 03-18-2019 09:04 PM
I am getting ready to upgrade my Unity to win 2k3. Do you have to have a hardened OS disk from Cisco or can I use a 2003 server enterprise with all the SP installed That I have purchased?
06-09-2008 11:36 AM
Hello Fabian,
Which version of Unity are you currently running? And Exchange?
If you can get it, use the Cisco provided Platform Configuration Disk. One benefit of this is that the PCD includes all the drivers that the server needs.
Customers with UCSS contracts who purchased their MCS servers from Cisco, are entitled to upgrade their operating system from Windows 2000 to Windows 2003 using the product number UNITY-OS-UPG-K9= for at no cost.
The doc also states that "We recommend that you install Windows using the Platform Configuration disc unless your customer requires that other applications installed on the server."
Hope this helps,
Michael.
06-09-2008 11:59 AM
Currently I am running Unity 4.2.1 on a win 2k OS.
06-09-2008 12:20 PM
Fabian,
So Unity is homed to Exchange 2003, correct?
Is you question on is your question on Win2k3 answered?
Michael.
06-09-2008 12:24 PM
Yes I am homed to exchange 2003. I am not sure what the rest of that reply meant. Thank you michael
06-09-2008 12:32 PM
Fabian,
I meant to ask if your question regarding which Windows 2003 media to use was answered, or if you needed any further clarification. Sorry I messed it up :-) Come on weekend!
Michael.
06-09-2008 12:34 PM
yes it was thank you Michael.
