Two Solution Engines Sharing a single, common Self Signed Cert
Jun 9th, 2008
Does anyone know if it possible to have 2 solution Engines sharing a single, common self signed certificate generated by one of the Solution Engines? I have a certificate, actually two, that are about to expire. I am trying simplify the distribution and management by having just one certificate.
Farrukh Haroon Mon, 06/09/2008 - 12:04
  • Red, 2250 points or more
This is the process to share SSL certs:
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Security&topic=AAA&topicID=.ee6e1fe&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc0c933
But why do you want to do this anyway? They are self-signed certs anyway, you can generate them for as long as you like. Are you using it for some sort of end-user security like Wireless Encryption, NAC etc.?
Farrukh
stephenwa Thu, 06/12/2008 - 09:04
The ACS generated Self Signed Certs are only valid for 1 year. As far as I know there is no way of generating one to last beyond a year unlike a cert obtained from a CA.
We are using the certs for WiFi PEAP clients.
Jagdeep Gambhir Mon, 06/09/2008 - 12:11
Yes, that is possible. If you have the cert and pvk file you can upload it to any appliance.
You need to remember private key file as you need to retype it at the time of uploading it.
~JG
Do rate helpful posts
