Rob Huffman Mon, 06/09/2008 - 15:07
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Rick,
If you create a new COS without "Allow access to Advanced Features" and assign the user to this COS you should be good to go.
Hope this helps!
Rob
RICK MANCINELLI Tue, 06/10/2008 - 04:21
Rob-
There isn't an "Allow Access to Advanced Features" option in the COS setup page? This is Unity Connection 2.0.1.
I figured out how to create a DN, and then use the related link to create a Unity VM Box, but it creates an orphaned vm box. As a result, I cannot set passwords or otherwise edit the user. Very strange. If I try to associate it with a CM user, it doesn't list my new user as an option.
Help!! :-)
Rick
