Maximum number of mac-addresses supported in metro ethernet platforms
Jun 9th, 2008
Is there a default maximum number of mac-addresess supported by the various platforms of Typical Metroethernet Switches..? 7609, 6500, 4503, 3750, 3550 & 3400. In such a case, may this number be increased by applying the sdm prefer command..? Does anybody of you know a document that explains this ?
Overall Rating: 5 (1 ratings)
n.nandrekar Tue, 06/10/2008 - 00:35
  • Silver, 250 points or more
hi!
6500 and 7600 support 64000 mac-address by default.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/product_at_a_glance0900aecd806a09f2.pdf
the 3750 will support 8000 or 2000 or 12000 based on the ether-switch module being used :
http://www.cisco.com/en/US/prod/collateral/routers/ps259/prod_qas0900aecd802a9470_ps282_Products_Q_and_A_Item.html
Cat4K (4912G) supports 16000 mac addresses.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/install/01intro.htm
SDM templates can be used to change the allocation of TCAM between L2, L3 and ACL tables to optimize the Tcam for perticular type of scenarios.
But SDM would be specific to a series of devices.
http://cio.cisco.com/univercd/cc/td/doc/product/lan/cat3750m/12114ax/3750mscg/swsdm.pdf
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_tech_note09186a00801e7bb9.shtml
The above 2 links give more detail on how the different templates affect the routing/switching/acl tables.
The command is available on 3700 and 3500 series where they share the same TCAM divided for L2/L3/ACL etc.
Higher end devices like 6500/7600 already have seperate TCAMs for L2/L3/ACL/Netflow etc. So the command and its use is not applicable here. There are enough resources available in these devices (which would explain their high costs).
Niranjan
