SSH and ASDM to Pix over VPN Client Connection
Jun 9th, 2008
How can we setup access to manage the pix (ssh and asdm) over a vpn client connection? We have given access to the pix via ssh and asdm to the VPN sunbet, but cannot access the pix. The commands we entered are below:
ssh 111.111.111.0 255.255.255.0 outside
http 111.111.111.0 255.255.255.0 outside
111.111.111.0 255.255.255.0 is our VPN subnet
Any ideas would be great. Thanks
cslitb Mon, 06/09/2008 - 20:46
Yes, we are using split tunneling. The subnet for the inside interface of the pix is 192.168.0.0. We can get to other devices on that same subnet (webservers, dns, etc) using the vpn client, but cannot access the pix with SSH or asdm. We have looked at the syslogs, but do not see anything out of the ordinary.
cslitb Tue, 06/10/2008 - 06:13
Currently we have this in our config:
http server enable
http 111.111.111.0 255.255.255.0 inside (tried both inside & outside)
management-access inside
Farrukh Haroon Tue, 06/10/2008 - 11:53
This might be a stupid question, but have you tried ASDM/SSH from the inside (normal LAN users)? just to make sure all is well (Crypto keys, ASDM image etc.)
Farrukh
cslitb Tue, 06/10/2008 - 12:45
Yes we have. We can both SSH and ASDM access to the Pix from the "inside".
cslitb Thu, 06/12/2008 - 14:43
Yes, it does terminate on the outside interface.
