Error msg while doing "get" , please let me know the possible reason
Jun 9th, 2008
rom Ciscoworks server is <!-- Executing: cwcli config get -u admin -p UGFzc3dvcmQx -ipaddress 10.67.25.240 -->
<cwcli> - Job Status: Job Failed
Partially Failed Devices:
10.67.25.240
<cwcli> ERROR - CM0062 Polling CENDSWUL02 for changes to configuration.
CM063 Error polling for change on PRIMARY STARTUP config, not fetching the config.
CM0065 No change in PRIMARY RUNNING config, config fetch not required
CM00 Polling not supported on VLAN RUNNING config, defaulting to fetch.
CM0060 VLAN RUNNING Config fetch SUCCESS for CENDSWUL02, version number 400 archived.
SUMMARY
SUMMARY
Partially Successful: get
Joe Clarke Mon, 06/09/2008 - 20:41
There was a problem with polling. Assuming this is a standard IOS device, this typically means a problem with the ccmHistoryStartupLastChanged object. That said, this output doesn't indicate a real error obtaining the config. The archive already had the latest running config archived.
