Downloading Activex Control
Jun 9th, 2008
Hi from Barcelona
I'm trying to setup Cisco ACS to use PEAP but before that I need to configure a CA on the server. I'm following the procedure found in http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a0080545a29.shtml but I have problems.
When I want to create a Server Certificate, I open the browser from ACS server and type http://localIP/crtsrv/; and when I submit the option 'Submit a certificate request to this CA using a form' , the browser keep thinking with message 'Downloading ActiveX Control'.
This is a W2K Server SP4 and It shouldn't happen. I've tried to install also Microsoft Patch found in Q330389, but it's only for SP3.
Any help
Dani
Farrukh Haroon Mon, 06/09/2008 - 21:58
Try to add the ACS server page to the list of trusted sites. Also make sure download of Active X is set to either Prompt or Allowed/Enabled.
Farrukh
