voice channel encapsulation
Answered Question
Jun 9th, 2008
I config the T1 cct (23B channels). what is the encapsulation setting? HDLC or PPP. I test both of them are working. which on is better?
rdgs
Correct Answer by paolo bevilacqua about 9 years 2 weeks ago
it doesn't make any difference. Encapsulation is only used for data and does not apply to voice.
Overall Rating: 4.5 (3 ratings)
spremkumar Mon, 06/09/2008 - 22:56
  • Red, 2250 points or more
it depends mostly on your requirement out there . if you are connecting to a non cisco box in the remote end do make use of ppp as encapsulation.
Also PPP encapsulation provides the option of bundling multiple links which you may require in future.
With HDLC u dont have the option of doing bundling multiple links and need to operate with single individual links..
regds
anitachoi3 Wed, 06/11/2008 - 06:31
The T1 is ISDN PRI. Those channels are b channels, for voice. Is it hdlc better for connect to another AS5400?
rdgs
Correct Answer
paolo bevilacqua Wed, 06/11/2008 - 07:21
  • Hall of Fame,
    Founding Member
