H.323 Trunk Configuration
Jun 9th, 2008
Please explain how I can configure h.323 trunk on 2821 voice gateway for service provider connectivity
Call Manager---Voice Gateway (h.323) -------trunk------- (h.323) Service Provider
And same voice gateway is connected to PSTN as well.
By the way can we configure h.323 trunk directly on call manager (note I don't have gatekeeper.)
Paolo Bevilacqua Tue, 06/10/2008 - 02:38
Hi, for IP-to_IP calls you will need CUBE image and license.
If you can trunk the CM directly to ITSP, then the GW is not necessary.
zeeshan.nadeem Tue, 06/10/2008 - 06:07
Please can you explain the how we can configure h.323 trunk ( Non gatekeeper control)on the Call Manager 5.1.
Paolo Bevilacqua Tue, 06/10/2008 - 06:12
For the CM, it is explained in the administrator guide.
For the GW, search for "CUBE" on CCO.
