ASA WAN & LAN Configuration
Jun 9th, 2008
I am Newbee to ASA configuration. recently we brought one ASA5505 i tried my level best to configure the ASA we are getiing PPPOE IP from ISP. after PC are not able to browse. from ASA i am able to ping the outside network. can any one please help me how to configure ASA .
please find the current configuration/
ciscoasa# sh run
: Saved
ASA Version 7.2(3)
hostname ciscoasa
domain-name cisco.com
enable password xxx
names
interface Vlan1
nameif outside
security-level 0
pppoe client vpdn group ADSLGROUP
ip address pppoe setroute
ospf cost 10
interface Vlan2
nameif inside
security-level 100
ip address 192.168.31.215 255.255.255.0
ospf cost 10
interface Ethernet0/0
interface Ethernet0/1
interface Ethernet0/2
switchport access vlan 2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
switchport access vlan 11
interface Ethernet0/7
passwd xxx
ftp mode passive
dns server-group DefaultDNS
access-list inside_access_out extended permit ip any interface outside
access-list inside_access_in extended permit tcp any eq www any eq www
access-list inside_access_in extended permit ip any any
access-list inside_access_in extended permit tcp any any
access-list outside_in extended permit icmp any any
access-list outside_in extended permit icmp any any echo-reply
access-list outside_access_in extended permit ip any interface outside
access-list outside_access_in extended permit ip any interface inside
pager lines 24
logging enable
logging asdm informational
logging debug-trace
mtu outside 1500
mtu inside 1500
ip verify reverse-path interface outside
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
asdm image disk0:/asdm-523.bin
no asdm history enable
arp timeout 14400
global (outside) 1 192.168.31.0-192.168.31.255 netmask 255.255.255.0
static (inside,outside) tcp 192.168.31.0 smtp 59.93.112.10 smtp netmask 255.255.255.255
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 59.93.122.1 1
route outside 0.0.0.0 0.0.0.0 59.93.112.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 192.168.31.0 255.255.255.0 inside
http 192.168.31.0 255.255.255.0 outside
http authentication-certificate outside
http authentication-certificate inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
vpdn group ADSLGrouP request dialout pppoe
vpdn group ADSLGrouP localname AdslLocalName
vpdn group ADSLGrouP ppp authentication chap
vpdn username ADSLUSENAME password ****** store-local
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
username user1 password xxx encrypted
prompt hostname context
Cryptochecksum:xxx
: end
Farrukh Haroon Tue, 06/10/2008 - 00:11
  • Red, 2250 points or more
You are missing a 'nat' statement. Also your 'global' statement is incorrect'
nat = what IP Addresses(s) to translate
global = Translate IPs mentioned in 'Nat' statement into WHICH public IP Addresses(s)
The nat and global statements should share the same sequence number (in your case 1)
nat (inside) 1 192.168.31.0-192.168.31.255 netmask 255.255.255.0
global (outside) 1 interface
Farrukh
Farrukh Haroon Tue, 06/10/2008 - 00:16
Also the following is recommend for PPPoE
mtu outside 1492
Farrukh
Farrukh Haroon Tue, 06/10/2008 - 11:07
Hello
Did you get this working?
Farrukh
nomair_83 Sun, 06/15/2008 - 04:58
  • Bronze, 100 points or more
Dear Where is nat:) ?
rsjavahar Sun, 06/15/2008 - 23:39
HI
i added the NAT statements but its not working .. from PC i can ping to Inside IP address but not able to ping to the Outside interface . Browsing is not working
please do the need .
Farrukh Haroon Mon, 06/16/2008 - 00:37
You will not be able to ping the 'outside' interface itself when sourcing your pings from the 'inside'. This is not allowed by the PIX/ASA.
Can you try to ping any public IP addresses from the PIX itself?
Also when you initiate traffic to the internet from inside, what do you see in the following:
show xlate
show conn det
Farrukh
rsjavahar Mon, 06/16/2008 - 00:52
Please find the current config . i am not able to browse internet ,
: Saved
ASA Version 7.2(3)
hostname ciscoasa
domain-name default.domain.invalid
enable password xxx
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
pppoe client vpdn group pppoex
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
passwd xxx
ftp mode passive
pager lines 24
mtu inside 1500
mtu outside 1492
arp timeout 14400
nat (inside) 1 192.168.31.0 255.255.255.0
http server enable
http 192.168.31.10 255.255.255.255 inside
telnet timeout 5
ssh timeout 5
console timeout 0
vpdn group pppoex request dialout pppoe
vpdn group pppoex localname ABCDEFGHI
vpdn group pppoex ppp authentication mschap
vpdn username ABCDEFGHIK password ********
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
Cryptochecksum:xxx
: end
ciscoasa(config)#
Farrukh Haroon Mon, 06/16/2008 - 01:47
show xlate
show conn det
show route (important)
It seems you have assigned a 'default gateway' to some IP, what IP is this? You already have 'setroute' option in PPP.
Farrukh
rsjavahar Mon, 06/16/2008 - 03:25
HI
I didn't add any Static IP in the configuration here find the output for the commands you asked
ciscoasa(config)# sh nat
NAT policies on Interface inside:
match ip inside 192.168.31.0 255.255.255.0 outside any
dynamic translation to pool 1 (95.93.117.66 [Interface PAT])
translate_hits = 0, untranslate_hits = 0
match ip inside 192.168.31.0 255.255.255.0 inside any
dynamic translation to pool 1 (No matching global)
match ip inside 192.168.31.0 255.255.255.0 _internal_loopback any
ciscoasa(config)#
ciscoasa(config)# sh run access-list
ciscoasa(config)#
ciscoasa(config)# sh route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is 95.93.112.1 to network 0.0.0.0
C 192.168.31.0 255.255.255.0 is directly connected, inside
C 127.1.0.0 255.255.0.0 is directly connected, _internal_loopback
S* 0.0.0.0 0.0.0.0 [1/0] via 95.93.112.1, outside
ciscoasa(config)#
ciscoasa(config)# sh conn detail
0 in use, 32 most used
Flags: A - awaiting inside ACK to SYN, a - awaiting outside ACK to SYN,
B - initial SYN from outside, C - CTIQBE media, D - DNS, d - dump,
E - outside back connection, F - outside FIN, f - inside FIN,
G - group, g - MGCP, H - H.323, h - H.225.0, I - inbound data,
i - incomplete, J - GTP, j - GTP data, K - GTP t3-response
k - Skinny media, M - SMTP data, m - SIP media, O - outbound data,
P - inside back connection, q - SQL*Net data, R - outside acknowledged FI
N,
R - UDP SUNRPC, r - inside acknowledged FIN, S - awaiting inside SYN,
s - awaiting outside SYN, T - SIP, t - SIP transient, U - up, W - WAAS,
X - inspected by service module
ciscoasa(config)#
ciscoasa(config)# sh xlate
0 in use, 0 most used
ciscoasa(config)#
ciscoasa(config)# ping 209.85.153.104
Sending 5, 100-byte ICMP Echos to 209.85.153.104, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 80/80/80 ms
ciscoasa(config)#
rsjavahar Mon, 06/16/2008 - 03:45
yes i got IP from the Service provider .. is it possible can i take your help through IM .. please
alanajjar Mon, 06/16/2008 - 05:12
I think the problem of internet browsing here is in the access list entry:
because the source port will not be www(80), it will be a random number above 1024, and the destination port will be www(80). so, to solve this problem just remove this entry, the other commands in this ACL is enough to enable internet browsing.
with regards
Farrukh Haroon Mon, 06/16/2008 - 05:53
That should not be a problem because the next line is:
Farrukh
alanajjar Mon, 06/16/2008 - 06:27
hi,
You are right, I thought it is deny statement.
with regards
