Fax Detection Application
Jun 9th, 2008
Dear sir
i wannted to know that is it possible that can i use Fax and voice call detection on same DID number without IVR?
as i m getting problem that some time call land on voice call ( ip phone) and some times automatically on fax. either its a fax cal or not.
I heard that i can use IVR for Fax Detection and voice call detection , but can i do this without IVR?
your assistance will be higly aaprecited
htarra Mon, 06/16/2008 - 12:46
Did you find documentation about FAX detection on the NM-HDA? If so please forward because I'm not aware of such a feature.
One possibility with CME would be to use the B-ACD script. Callers would hear a greeting, then a menu that you can use to send to fax port, or possibly if they don't enter any choice they are sent to the fax by timeout.
