PIX 6.3.5 disabling Xauth and Modecfg for one peer
Jun 10th, 2008
The PIX is used as Easy VPN server and L2L gateway in the same time. I have difficulties with a new L2L VPN (isakmp authentication rsa-sig) because the PIX sends Xauth and Modecfg requests and the peer (Linux box with OpenSwan) tries to interpret them (received MODECFG message when in state STATE_MAIN_I4, and we aren't xauth client) and the VPN setup fails after phase 1.
I tried to disable Xauth and Modecfg for this peer with "isakmp peer fqdn FQDN no-xauth no-config-mode" but the PIX still sends the Xauth and Modecfg requests.
Can anyone give a clue what FQDN should be? (from DNS using reverse lookup for peers IP, or the FQDN from the certificate, any other tips?)
aghaznavi Mon, 06/16/2008 - 07:53
Try this no crypto xauth interface-name in the specific interface . Where interface is the crypto map intf or IKE endpoint for bypassing the authentication.
orbanattila Tue, 06/17/2008 - 00:06
It's not a valid command ...
(config)# no crypto xauth outside
Invalid keyword: "xauth"
As I mentioned earlier Xauth cannot be disabled globally because is needed for EZVPN.
Thanks anyway
