Warning message
Login into switch
Jun 10th, 2008
Pls, help asap. I have got problems with login into a switch. I have just copied and pasted the Telnet pw as given. It reported "bad password" each time. I don't know what that "7" here means. I want to believe is the user number.
hostname CSIGBN08
enable password 7 12CV52566SA5844WDD
line con 0
line vty 0 4
password 7 556A66ADA46SAS46ASS6646646
login
line vty 5 15
password 7 12AS5455S5656ADAS466A4F56G
login
Overall Rating: 3.3 (3 ratings)
n.nandrekar Tue, 06/10/2008 - 00:49
  • Silver, 250 points or more
The number "7" there is the access privilage there. I hope that you are not copying it along with "7".
Second thing is that, have you given that string as password? I think that there was some other password and "service password-encryption" was enabled. What you are seeing there is not the actual password but a hash value (encrypted password).
You cant copy paste that for the password.
Niranjan
( Please rate the post if it solves your issue.)
Sundayfat Tue, 06/10/2008 - 01:02
Thanks for your reaction. I received "Bad password". I had copied and pasted the password without the 7, when it failed. I tried again with the 7. I realised the pw- is hashed / encrypted. But, the "sh run" output is what the former administrator sent to, as the pw. What do your suggest ?
royalblues Tue, 06/10/2008 - 01:03
  • Green, 3000 points or more
Just a small correction to Niranjan's post
The number 7 actually means that the password has been encrypted with the weak algorithm and can be reversed using online password breaking tools
http://www.cisco.com/en/US/tech/tk59/technologies_tech_note09186a00801d7efa.shtml
you can use some online passowrd breaking tools to get the passowrd eg.
http://www.ifm.net.nz/cookbooks/passwordcracker.html
Narayan
n.nandrekar Tue, 06/10/2008 - 04:06
Hi!
Thanks for pointing out the mistake! :)
Pravin Phadte Tue, 06/10/2008 - 01:08
Niranjan is not right with the number 7.
Its not the privilage.
all passwords and other authentication strings in Cisco IOS configuration files are encrypted using the weak, reversible scheme used for user passwords.
To determine which scheme has been used to encrypt a specific password, check the digit preceding the encrypted string in the configuration file. If that digit is a 7, the password has been encrypted using the weak algorithm. If the digit is a 5, the password has been hashed using the stronger MD5 algorithm.
For example, in the configuration command:
enable secret 5 $1$iUjJ$cDZ03KKGh7mHfX2RSbDqP.
The enable secret has been hashed with MD5, whereas in the command:
username jdoe password 7 07362E590E1B1C041B1E124C0A2F2E206832752E1A01134D
The password has been encrypted using the weak reversible algorithm.
Below is the link which can provide you with more information.
http://www.cisco.com/warp/public/701/64.html
When you provie with the command "service password-encription" you will see the output as you have pasted above.
The password followed with 5 cannat be decripted since its MD5 algorith. 7 can be.
Privilage config would be seen like below in running config.
username cisco privilege 7 password 0 cisco
And yes the pasword with 7 can be broken using tool. Boson has one.
Hope this helps.
Sundayfat Tue, 06/10/2008 - 01:27
Hi, Niranjan. I very much appreciate your assistance here. Just to bother further, do you think when I send syntax "sh tech-support" in EXEC user mode of that Switch,I shall get the output to have the password so needed. I have only access to the user mode, for now- thru console connection. Just send me what syntax I need send pls. Thanks once more
Pravin Phadte Tue, 06/10/2008 - 02:37
1st the show tech-support would not work in EXEC user mode.
In fact if you give show tech-support you will not get the password.
Below is how the output would look for show running config in tech-support.
enable secret 5
username cisco password 7
line con 0
exec-timeout 0 0
line vty 0 4
password 7
length 0
line vty 5 15
password 7
Hope this helps.
Pravin
Tim Smith Tue, 06/10/2008 - 03:34
Have you unencrypted the password and tried it as the other guys suggested?
Do you have physical access to the switch?
If so, you could do a password recovery.
All the procedures are listed on the Cisco site.
Just to note - it will be service impacting however.
Cheers,
Tim
