Ciscoworks help
Jun 10th, 2008
Hi All,
We are using Ciscoworks v3. I need to find out exactly how many ports in total we have in all the switches that are in our network/ciscoworks. This is for both active and inactive ports. Where can i get this info from?
We have SNMP setup on the switches and ciscoworks can see all the switches, i just need to know exactly which menu item i go to if i want to see number of existing ports.
Joe Clarke Tue, 06/10/2008 - 07:58
You can run a Campus Manager Port Attributes report to get a list of all switch ports are in the whole network. Go to Campus Manager > Reports > Report Generator. Select the Port Attributes report, and select your Switches and Hubs Device Type Group.
tinu.karki Fri, 06/13/2008 - 04:18
I dont have that option within campus manager. Only options i have under campus manager is Topology services, path analysis, user tracking and VLAN port assignment (see attachment). Could it be anywhere else?
yjdabear Fri, 06/13/2008 - 06:23
This screenshot shows CiscoWorks LMS 2.2 or older. It's ~2 generations behind 3.x and will reach its "Last Date of Support" on July 31, 2008
