Discounts on Software
Jun 10th, 2008
I was told but not sure that if you hold a CCNA cert, it will allow you to get discounts on software through Microsoft or other retailers.
Is this true and if so what web site would I have to go to get these discounts
B
jim_berlow Wed, 06/11/2008 - 10:39
There is no truth to this, whatsoever. With a CCNA you receive a certificate and get access to the certification portal on Cisco - that's it! The only other benefit is that you can use the logos and tell folks you are Cisco certified.
Cisco doesn't have any relation to any other vendor for discounts.
