LMS 2.2
Jun 10th, 2008
Dear All,
Due to some reason I have to install & configure LMS 2.2 this time where everybody going for 3.1.
I have never experience with 2.2. The interface is totaly different .The sub-menus are different.
I need small help at this stage that when I am configuring the snmp credentils in SERVER CONFIGURATION>ANI SERVER>SNMP SETTINGS it is taking. After typing all the strings & other parameters when I am saving the same its not saving. Because of that I am not able to discover the devices.
Can anybody pls help me in this regard?
Thanks in advance
Joe Clarke Tue, 06/10/2008 - 08:06
You should know that as of July 1, LMS 2.2 will no longer be supported.
For this problem, you should check NMSROOT/campus/etc/cwsi/anisnmp.conf and make sure it has permissions for casuser to be able to write to it.
sachidananda panda Tue, 06/10/2008 - 23:36
Sorry for bothering you. I knew the EoS by July 1 but still there is reason to install it.
Thanks for your kind help & advise.
