Eigrp redistribution problem
Jun 10th, 2008
Dear all,
There are two branch offices of a customer connected to a PE router. One of this link(CPE1) use EIGRP as PE-CE protocol and the other one(CPE2) use STATIC.
I have attached a diagram to get a clear idea.
I have redistributed the EIGRP routes to MP BGP and vice versa. Similarly STATIC routes are redistributed to MP BGP and vice versa.
Will the static routing entry (Network X) be advertised to the CPE1 router?
or do i need to put redistribute static inside the eigrp address family to send the Network X entry to CPE1?
I have checked it, i need that redistribution of static route into Eigrp address-family. But i feel there may be any problem. Please advice me.
jayanthan.T
Overall Rating: 4 (1 ratings)
lee.reade Tue, 06/10/2008 - 03:36
As long as you have redistributed eigrp into MPBGP onsite site 1 (vlan100) and have redistributed static into MPBGP on site 2 (vlan200), this will create the VPNV4 router on the PE.
All you will need to do now, is make sure that the VRF for site 1 imports the routes that the VRF for site 2 exports, and vice versa.
For example;
ip vrf vlan100
rd 100:100
route-target export 100:100
route-target import 100:200
ip vrf vlan200
rd 100:200
route-target export 100:200
route-target import 100:100
Then under the address family for eigrp for site 1 vlan100 vrf, redistrbute bgp in.
For site 2 vlan200, you will need either a default route on the CE, or a static route to site 1 vlan 100 networks.
Hope this helps.
Cheers
LR
jayanthan Tue, 06/10/2008 - 04:50
Thanks for the response LR,
This two links belons to the same customer.
ip vrf MTN
description ***MTN***
rd 65500:1013001
route-target export 65500:1013001
route-target import 65500:1013001
### eigrp interface ###
interface GigabitEthernet0/1.41
description *** DTL IT UNIONPLACE 48Mbps***
encapsulation dot1Q 41
ip vrf forwarding MTN
ip address 192.168.29.2 255.255.255.252
no cdp enable
end
### Static Interface ###
interface GigabitEthernet0/1.269
description *** MTN SOFT LOGIC - WELLAWATTA COL 06 ***
encapsulation dot1Q 269
ip address 10.1.0.118 255.255.255.252
service-policy output 512K
no cdp enable
end
### Static route ###
ip route vrf MTN 172.21.204.160 255.255.255.240 10.1.0.117
### EIGRP CONF ###
router eigrp 1
address-family ipv4 vrf MTN
redistribute bgp 65500 metric 128 1900 255 1 1500
network 192.168.29.0 0.0.0.3
no auto-summary
autonomous-system 200
exit-address-family
### BGP CONF ###
router bgp 65500
redistribute connected
redistribute static
redistribute eigrp 200
default-information originate
no auto-summary
no synchronization
exit-address-family
Do i need to add the following command eigrp address family to send the route to CPE1?
router eigrp 1
redistribute static metric 128 1000 100 1 1500
Regds,
Jaya.
lee.reade Tue, 06/10/2008 - 05:14
From what you have posted, it should be getting redistributed already, static-bgp-bgp-eigrp.
I have not tried this kind of setup before, so I would suggest that you try to redistribute the static into the eigrp address family direct, as you have mentioned above.
Can you post from the PE, the following;
show ip bgp vpn all
show ip eigrp 200 topology
Cheers
LR
jander2008 Tue, 06/10/2008 - 07:56
Hi Jaya:
Yes, you need to redistribute static under eigrp config too (even though you have it under BGP).
If you run more than one PE-CE protocol on the same PE that connects the 2 CE's you have to redistribute the routing protocol b/w them in addition to under BGP.
Same goes if you were running RIP or OSPF on one PE-CE link.
You have to redistribute RIP/OSPF into BGP + EIGRP and vice-versa.
Hope this helps.
Best Regards.
JD
jayanthan Tue, 06/10/2008 - 08:25
Hi JD and LR,
I think JD is correct. I also have tested and without redistributing static into eigrp it does not work.
I also expect to receive the route in the following way.
Static --> MP Bgp --> eigrp
It does not work.
We need to have
Static -->
MP BGP
EIGRP -->
and
STATIC --> EIGRP
bye.
Rgds,
jaya.
waleed_amer Tue, 06/10/2008 - 09:59
1-static --> bgp you will get the route in bgp table but will not be selected in the vrf routing table so it will not get through bgp-eigrp so you have to redistribute static into eigrp.
2-if you don't have branches connected to another PE so no need to redistribute routes into MP-BGP.
Regards,W.Amer
jayanthan Tue, 06/10/2008 - 10:32
Now i got the idea.
Not the routes in the bgp vpnv4 vrf table are redistributed into eigrp.
But the BGP routes in the vrf routing table are redistributed into eigrp.
am i correct?
thanks.
Rgds,
jaya
waleed_amer Tue, 06/10/2008 - 10:41
yes the route has to be selected and installed into the global or vrf routing table to be redistributed.
Regards,W.Amer
