delay before getting phones ringing
Answered Question
Jun 10th, 2008
I installed a CCM 4.1(3) with a Cisco 2801 (VWIC-2MFT-E1) as voice gateway. I experience a serious issue when dialing a interna extension : it takes like 10 seconds before the phone rings. Pls helps !
Correct Answer by Michael Owuor about 8 years 8 months ago
Hi Dominique,
Is the delay experienced when calling from IP phone to IP phone? Is it experienced when calling from PSTN through the 2801 to IP phones? Are there any type of patterns such as route patterns that overlap with the extensions on the phones?
Michael.
Overall Rating: 5 (1 ratings)
Correct Answer
Michael Owuor Tue, 06/10/2008 - 04:47
Hi Dominique,
Michael.
dom.a Wed, 06/11/2008 - 01:56
It was due to an overlap of route patterns. i have sorted this out. it is good now !
Rob Huffman Tue, 06/10/2008 - 04:51
Hi Dominique,
Hope all is well :)
This type of delay is usually caused by an Overlap in the Dialplan. For example DN's that are 8xxx and a RP that begins with 8. The best way to fix this is to remove any overlapping patterns. You can also look at this CCM Parameter (Interdigit Timeout);
Here is the method to change the "interdigit timeout";
Complete these steps to modify the settings:
Select Service > Service Parameters to go to Cisco CallManager System Parameters from the Cisco CallManager 4.1(x) Administration page.
Select the name of your server and service from the Server and Service fields.
Select TimerT302_msec.
In the Value field, type the timeout you want to configure (specify the time in milliseconds). For example, if you want to configure 5 seconds as the interdigit timeout, type 5000.
Caution: Be careful. Do not set the interdigit timeout value too low, otherwise the user does not have enough time to enter the digits while calling.
Click Update.
Restart Cisco CallManager to implement the changes.
From this excellent doc;
Delay in Call Establishment: Configuring the Interdigit Timeout
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00800dab26.shtml#solution3
For a nice description of Numberplan overlap see this from Jaime;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&topicID=.ee6c829&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cc04ed9/4#selected_message
Hope this helps!
Rob
Michael: Your skills have trumped my useless typing skills once again ;-)
