Telnet/SSH Console Window
Jun 10th, 2008
I have setup the clientless SSL VPN. All is great, however I when I setup the telnet or ssh plugins the screen is very small. Can I change size of the screen like I can with RDP?
Farrukh Haroon Tue, 06/10/2008 - 12:21
  • Red, 2250 points or more
I posted two solutions to this on an earlier post, but the guy did not respond.
I would be glad if you could test one or both of these, I don't have access to a 8.x box right now to test this out:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Virtual%20Private%20Networks&topic=Services&topicID=.ee6bd84&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc0ae97
Farrukh
melcara Tue, 06/10/2008 - 18:19
I will try this out this weekend and post the reponse.
melcara Wed, 06/25/2008 - 03:37
I have tried the modification to JAR file, but this seems crazy, I can't seem to be able to recreate jar file. any ideas
melcara Wed, 06/25/2008 - 04:05
I have also modified the jta.html and can not import the file, can you tell me how to do that?
Farrukh Haroon Wed, 06/25/2008 - 05:43
have you tried the regular Copy functions of the ASA? Edit the file on your PC and then copy it to the ASA. The other workaround would most probably require modifying the .jar file and then installing it on the ASA.
Farrukh
melcara Wed, 06/25/2008 - 16:16
I can't seem to copy the file to location on Disk0:/
Farrukh Haroon Wed, 06/25/2008 - 23:22
What is your current working directory?
pwd
What is the specific command you are trying and what error are you getting? Can you post both over here?
Farrukh
purohit_810 Fri, 06/27/2008 - 20:16
  • Silver, 250 points or more
You have directly uploaded plug-in. Didn't saved in Disk0:/ that is why.
Dharmesh Purohit
melcara Wed, 07/09/2008 - 03:42
so once I modify the plugin, how do I import it without directly uploading the plugin. would it not be easier just recompile the files into a *.jar and import it again. I just can't seem to recompile it correctly.
purohit_810 Fri, 06/27/2008 - 20:15
I think you can't. There is nowhere like adjustment.
Dharmesh
