How do I identify what trigger was called and route call to a menu step?
Answered Question
Jun 10th, 2008
What script logic will allow me to see what trigger was called?
I want to identify what trigger the contact came in on and take the caller to a specific menu step.
Correct Answer by adignan about 8 years 10 months ago
You want to use the "Get Call Contact Info" step to get the "Original Called Number". Sample script attached.
adignan - CDW
*please rate helpful posts
Overall Rating: 5 (1 ratings)
Correct Answer
adignan Tue, 06/10/2008 - 05:14
  • Blue, 1500 points or more
adignan - CDW
asafayan Tue, 06/10/2008 - 10:35
Now I see how to capture the called number - but how do I map this to a specific menu step?
I see lots of other posts suggesting to use a Match step but don't see that option in my script editor.
adignan Tue, 06/10/2008 - 11:34
There are a few ways to do it. Attached is one.
If the Original Dialed Number is 4000 go to one menu and if its 5000 go to the other menu.
Again, numerous ways to slice this but hopefully you get the picture.
adignan - CDW
asafayan Wed, 06/11/2008 - 05:41
Hi Adignan,
I'm attaching my completed script. I appreciate your help.
Can you do a quick once over and let me know if anything jumps out at you as this is only my 2nd script!
I was wondering if there was any more efficient way to handle bilingual (english/spanish) function rather than creating two completely separate MENU structures - one for english and one for spanish.
Amir
