Where to find NAC .adf files?
Jun 10th, 2008
I'm currently setting up my first implementation of the NAC framework in a lab environment and detailing the necessary components, including anti-virus vendors, etc...but I'm having trouble finding any .adf files for importing into the Cisco ACS server. I believe these are to come from the application vendors themselves, but I'm unable to find anything on any of the supposedly supported vendors pages (avg, norton, trend, etc). Does anyone have any info on how to go about finding these .adf files, is there some central place? Thanks very much.
smahbub Mon, 06/16/2008 - 13:21
For posture credentials from a third-party vendor, you must import the corresponding NAC attribute definition file (ADF).
Refer the following url for more info on importing .adf files into the Cisco ACS server:
Also refer the "Import Partner AVPs" section in the following url:
