joe_ironport Tue, 06/10/2008 - 20:33
MFC doesn't run on an IronPort appliance. It will run on a Wintel server. I believe you can contact customer care for download info.
Joe
pvdberg00 Mon, 06/16/2008 - 07:45
What release of aSyncOS do you use ? With version 6.x you can do on box tracking and reporting.
Peter.
wmchurch_ironport Mon, 06/16/2008 - 18:57
Peter:
If your running AsyncOS 6.x MFC is really only helpful if you have multiple C/X series appliances and you don't have an M series.
As long as you have AsyncOS 6.x, I'd highly recommend it by the way, on-box message tracking is way better (faster, cleaner, more options) with 6.1 than MFC 1.3/1.4 is, and you don't require another server to run it.
Otherwise it's a toss up, I like the findevent / grep functionality via CLI myself. :)
pvdberg00 Tue, 06/17/2008 - 10:00
Bill,
We are using aSyncOS 6.3 with message tracking and reporting on the M Serie. I think it is much better then MFC 1.3/1.4.
