Cisco 7921G can not associate with any Access Points
Jun 10th, 2008
Hi Friends.
I have a big solutions of IP telephony with Cisco IP Phones 7920 and 7921G, the 7920 are working perfect, but the 7921G are not???, I configured the 7921G, but the profile appears like INACTIVE??, I tried a lot of times to put the profile enable but it continues INACTIVE??, and the 7921G can not make a link with the Access Point Cisco 1131G, into the 7921G screen appears Connection failed??. All the 7920 IP phones are authenticates with Access Points in order to connect with its Call Manager. But 7921G does not work properly Could you help me. So I tried with the default profile with profile 1" and SSID "cisco" and use open authentication, but notihig happend.
I have accessed by web interface by USB connection but the profile that I am using appear like the picture that I am sending you?. How can I fix this issue??
Best regards
Rafael Barba
Anonymous (not verified) Mon, 06/16/2008 - 12:38
On the phone try the security mode with PEAP selected along with the username and password and/or also try it with AKM selected with the username and password and see if it makes any difference.....(since these are the only 2 ways to configure it on the phone)
r.barba Mon, 06/23/2008 - 09:39
Hi Could you try thios command into the interface radio0.
#interface Dot11Radio0
world-mode dot11d country US both
I think that with it the phones works fine.
regards
Rafael Barba
