VPN clients ping LAN after reconnect only
Jun 10th, 2008
Hi all,
cisco 2801, ios c2801-advipservicesk9-mz.124-9.T1.bin
VPN clients connect fine all the time, obtain ip addresses, but sometimes as ever they become connected they can't access internal hosts. To ping LAN they should reconnect again. Three-four attempts result two-three succesful ones. What d'u think? Thanx a lot.
A. Atroshchenko
Farrukh Haroon Tue, 06/10/2008 - 11:50
Please try to upgrade to the latest VPN client software and then check.
Somtimes the 'Deterministic Network Enhancer' enabled on NIC cards in Windows XP is causing problems, try to toggle that on/off.
a.atroshchenko Wed, 06/11/2008 - 01:20
Latest VPN soft gives the same result. Concerning NIC-your mean virtual NIC which becomes up when connection appears?
