1760 with vic 4fxs/did card
Answered Question
Jun 10th, 2008
I have a 1760 router that have two wic cards on slot 0 and 1. And 2 vic 4fxs/did cards on slot 2 and 3.
Problem is that the two vic4fxs/did cards, don't show up on hardware list, there is a green light on the slot 2 and 3 that is OK, the 4 ports on each card are amber, but the router doesn't reconize the card.
Is ther any comand that I have to do to enable the card on the slot, for fxs?
Correct Answer by Paolo Bevilacqua about 8 years 8 months ago
Most likely you're missing the necessary DSP module to support the voice interface.
Do "show diag" to see what do you have in the router.
For example, a PVDM-256K-8 would be enough for 8 analog voice ports, but not for additional ones.
Overall Rating: 5 (2 ratings)
Correct Answer
Paolo Bevilacqua Tue, 06/10/2008 - 07:00
diastiago Tue, 06/10/2008 - 07:08
Slot 0:
C1760 1FE VE 4SLOT DV Mainboard Port adapter, 12 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 6.0
PCB Serial Number : FOC091716SP
Part Number : 73-7167-06
Board Revision : A0
Fab Version : 04
Product (FRU) Number : CISCO1760
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 16 41 06 00 C1 8B 46 4F 43 30 39 31
0x10: 37 31 36 53 50 82 49 1B FF 06 42 41 30 02 04 FF
0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Packet Voice DSP Module Slot 0:
Not populated
Packet Voice DSP Module Slot 1:
Not populated
WIC/VIC Slot 0:
Serial 1T
Hardware revision 1.0 Board revision J0
Serial number 0028151857 Part number 800-01514-01
FRU Part Number WIC-1T=
Test history 0x00 RMA number 00-00-00
Connector type WAN Module
EEPROM format version 1
0x20: 01 02 01 00 01 AD 90 31 50 05 EA 01 00 00 00 00
0x30: 98 00 00 00 11 11 02 01 FF FF FF FF FF FF FF FF
WIC/VIC Slot 1:
Serial 2T (12in1)
Hardware revision 1.0 Board revision B0
Serial number 0031961241 Part number 800-03181-02
FRU Part Number WIC-2T=
Connector type PCI
0x20: 01 12 01 00 01 E7 B0 99 50 0C 6D 02 00 00 00 00
0x30: 58 00 00 00 04 03 26 00 FF FF FF FF FF FF FF FF
VIC Slot 2:
Quad FXS DID Voice Interface Card
Daughter card-Version 4 TLV Cookie Format
Hardware Revision : 3.1
Part Number : 73-6918-02
Board Revision : E0
Deviation Number : 0
Fab Version : 02
PCB Serial Number : FOC11131MR4
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Top Assy. Part Number : 800-17016-02
Connector Type : 01
VIC Slot 3:
Board Revision : E0
Fab Version : 02
PCB Serial Number : FOC11131MSQ
RMA History : 00
Connector Type : 01
