Need help with translation rules and CME
Hey guys I have a CME system at my small business and I am now in need of translation rules because my internal 3 digit numbering plan conflicts with some area codes in the US.
I want users to have a dial a 9 then the 10 digit phone number for local calls.
I also want users to have dial a 9 then 1 then the 10 digit number for long distance.
However my provider will only accept the 10 digit phone number for both local and long distance calls.
Any help is appreiciated.
Overall Rating: 5 (2 ratings)
paolo bevilacqua Tue, 06/10/2008 - 07:08
  • Hall of Fame,
    Founding Member
No need for translation rules in this case:
dial-peer voice 9 pots
description local calls
destination-pattern 9[2-9]......
prefix 408 <- your area code here
port x/y
dial-peer voice 91 pots
description long distance
destination-pattern 91[2-9][0-8].[2-9]......
forward-digits 10
port x/y
paolo bevilacqua Tue, 06/10/2008 - 07:33
  • Hall of Fame,
    Founding Member
You should have mentioned the SIP trunk :)
voice translation-profile 9-to-area
translate called 100
voice translation-profile strip-9
translate called 101
voice translation-rule 100
rule 1 /^9/ /408/
voice translation-rule 101
rule 1 /^91/ //
dial-peer voice 9 voip
translation-profile outgoing 9-to-area
dial-peer voice 91 voip
translation-profile outgoing strip-91
We have to dial 10 digits here in Houston.
I think translation rule 100 needs to look like this:
rule 1 /^9/ //
Correct?
What should the destination pattern read? I tried this config real quick and it didnt work so i had to revert back.
I used 9[2-9]......... for the destination-pattern on the dial peer.
What did I miss? Any way to test the translation rules before applying them?
paolo bevilacqua Tue, 06/10/2008 - 08:35
  • Hall of Fame,
    Founding Member
Hi, seems to me the rules are right, of course replace my example 408 with your area code.
You can "test voice translation-rule XXX YYY".
Thanks for the appreciation and good luck!
paolo bevilacqua Tue, 06/10/2008 - 09:07
  • Hall of Fame,
    Founding Member
NANP:
Area code (3), exchange code (3), number (4) = 10
BUT, you also need to remove the 1 used for long distance in the US.
So the rule should be really
rule 1 /^91/ //
That removes the leading 91. If you are supposed to leave 1 in place, you'll be calling 11 digits, not 10.
For local and long distance numbers I DO NOT have to dial a 1. I need to give my phone company 10 digits period. I want my internal users to dial a 9 then the 10 digit number for local calls. For long distance I want my internal users to dial a 91 then the 10 digit number.
Remember my phone company will only accept a 10 digit number no matter if it is long distance or local. They dont care one way or the other.
paolo bevilacqua Tue, 06/10/2008 - 10:29
  • Hall of Fame,
    Founding Member
Well, that is exactly what the rules I suggested above do.
For local calls, leading 9 is replaced with you area code. For long distance, leading 91 is removed. In both cases, 10 digits are sent.
I suppose that for international, 011 has to be prepended and destination-pattern would look like: 011[1-9].....T
Another translation-profile and rule would ensure that 9 is prefixed to calling number for incoming calls, this to facilitate callback.
You can check which number is ultimately sent to ITSP with "debug ccsip message" and "term mon".
paolo bevilacqua Tue, 06/10/2008 - 11:04
  • Hall of Fame,
    Founding Member
But that will make users dial 9 followed by 10 digits, that I think is not customary in the U.S.
I guess you've to decide which one of the three area codes is your "local" one.
paolo bevilacqua Tue, 06/10/2008 - 12:49
  • Hall of Fame,
    Founding Member
Have to admit I misunderstood the 9 + 10 digits thing since the very beginning.
I also do not understand what is the point to have to remember that for three area codes only, no 1 needs to be dialed. In my way of thinking, either 1 or no 1, all calls should go through.
Anyway, what do you want is done with:
voice translation-profile strip-91
rule 1 /^91/ //
rule 1 /^9/ //
dial-peer voice 9281 voip
destination-pattern 9281[2-9]......
translation-profile outgoing strip9
dial-peer voice 9713 voip
destination-pattern 9713[2-9]......
dial-peer voice 9932 voip
destination-pattern 9832[2-9]......
allenelson Fri, 06/13/2008 - 12:28
how about predot trailing # discard? i've just decided to move from MGCP to h323 and am having a hard time figuring that one out..
paolo bevilacqua Sat, 06/14/2008 - 03:27
  • Hall of Fame,
    Founding Member
HI, discussion was about a CME where SIP is used to ITSP. H.323 and MGCP do not apply in this case.
